draftsight: right tangent to two circles
  • Thread starter Thread starter Paolo118
Paolo118
Good morning.
Here is the dilemma:
I have to draw a two-round bribe line in draftsight, but I can't. I can draw it tangent to a circle, but not to two.
suggestions?
Thank you, good day
I don't know where the dilemma is, because it's always been possible.
Of course if you work with a thousand thousand thousand sect osnap, without taking into account the incompatibility practices, it does not come.
if you manually request the osnap through the floating selection window (ndr: shift+clickdx) and you pass the "paura" of the indication "replaced speaker", it all comes perfectly!
Have a good day.
I find myself a continuation of the discussion by mail dd. 3 July.
I receive from paolo118:
mah, tangent postponed do not have it and if they select tangent, it is displayed:
"unrecognized command. press f1 for assistance. "
interpreter and comment:
It is obvious: you should not start by asking bomb (from floating menu osnap) "tangent" (which is not a command).
I propose a step-by-step:
- you must already have the 2 circles in question
- you ask the command "linea"
- leaving the option, to the command line request "specifies the initial point>»" activates with shift+clickdx the floating menu of choice osnap
- select with a "tangent" clicksx
- to the request "a" in command line (with contextual appearance in graphic area of the indication "replaced speaker") you work mouse "mirando" on the 1st circle to the dial (trigonometrically understood) from which you want to start the line and you run a clicksx
- to the command line request "specific next point" is required with shift+clickdx the floating menu of the osnap
- you select again with a "tangent" clicksx
- (you miss the "replaced speaker" in the graphic area, at this moment a bit misleading) while in the command line a "a" appears, in the graphic area on the 2nd circle you mix on the dial (c.s.) on which you want to get the line and follow a click-sx.
I hope the dilemma is resolved.
Good events to all.
