draw a thread
  • Thread starter Thread starter degre89
degre89
I have a little problem, I used the search button but I couldn't solve the problem.
practically I have to fill the inner part of a cylinder with hole from 35(I should make a thread of 35x1).
pear in the drop-down menu of the choice of threads I see only tr 38x3 and tr 42x7.
using the search button I saw that there was to edit the file holes.txt, opening the file but I see that of threads there and are many more and not only the two that the menu proposes me.... .
Any idea?
Don't you first create a threaded hole of m35?
if there is not in the options of threaded holes you can always change the file holes.txt accordingly pipes.txt for tubes or cylinders, so you always stay saved and you will always find it when you want.
Bye.
Any idea?
in the file holes.txt there are all threads that solid edge knows. the drop-down menu only shows you what fits your pre-light or the male you're drawing.
to add a thread then, you just have to add a row to the holes.txt file and save. Then the new thread will appear on the drop-down menu.
