Nenes1992
Hi, I have to represent the gate attached with autocad, but being full of curves I was wondering if someone had a valid solution. . I press that I know the program enough and I tried with the polylines but exploding them then a mess happens.. as it was designed in dwg I'm almost certain that all those curves are feasible with some command that I don't know maybe or with an extension of cad.. ideas? this job is very urgent so there should be a pretty quick solution without curing each line otherwise it takes 2 weeks! Thank you!
