BonzoRosso
Good morning.
I found this problem:
I need to create a drawing of a assembly and tie it to the desired axieme with bom relative to its content, but starting from the graphics of a higher level set.
I can create the scenario at the top level and all the views at the drawing level but I cannot apply the bom of the desired axieme, because the views point to the upper axieme. . .
I could insert a cluster at the structure level and set it as just non-configurative at the bom level but I should insert every time in each set all the encumbrances.
How can I solve this?
