enrico1979
hello to all boys
I have never taken much into account the 2d of pro and (I used autocad for quotation) while I have to learn now.
I'll explain my problem by hoping to be clear.
when I use it shows model annotations and selection in axis type, pressing the last icon of those available, I can insert the axes of the holes that otherwise I do not know how to highlight (I did not define them drawing the 3d but for the quotation are fundamental ).
Now when I point out the axes to me of interest, in addition to the reference line it appears next to the name that is assigned to it by default (type a-1) that I can not eliminate in any way (it will be a question of some configuration since seeing some tutorials I noticed that through the identical passage, the antipathic note does not appear, as it is right that it is as from what world and world the axis of symmetry accompanied by an example
Can you tell me how to solve the problem? ?
if you can follow an alternative method to define the reference axes is absolutely well accepted (from insert axes I can not do anything)
hi and good work at all
