Drilling / automatic blade
  • Thread starter Thread starter pierluigip
pierluigip
Good morning to all
I would like to see if it was possible to drill a sheet in automatic (with a pre-set hole) to insert and/or place the component I insert,
I attach the example of the portald on the sheet,
Good job
You should create a smart component. the required hole will be created on the support face at the time of insertion.
exactly. with smart components or smart components (explained in tutorials) when placing an object on another, the corresponding processing is created to accommodate it.
