andreaf93
Good morning to all,
I should create a repetition of a drilling on oval surface of which I attach photos.
in the past on a perfectly circular surface I used the winding function and then circular repetition so as to repeat the cut on the whole surface; in this case when drilling on an oval surface the circular repetition is not correct.
(Surely it will be a very simple passage but having always worked sheet and not solid I struggle to understand which function/procedure to use).
