drug problem
  • Thread starter Thread starter robyroby
robyroby
Good evening.
I ask for help because I added to the hydraulic circuit of my carraro tractor tigrone 4800 l'hydroguida. everything works, the only problem is that when the lift goes to the end of the stroke the piston tends to go into pressure by slightly steering the wheels only from one verse. lapompa was replaced with a larger one and the hydroguida incorporated the maximum valvoa.
I'll get you a circuit board. someone can kindly give me some tips... thank you
Good evening.
I ask for help because I added to the hydraulic circuit of my carraro tractor tigrone 4800 l'hydroguida. Everything works,
If everything worked, you wouldn't be here writing;-)
the only problem is that when the lift goes to the end of the stroke the piston of the hydroguida tends to go in pressure by slightly steering the wheels only from one verse. lapompa was replaced with a larger one and the hydroguida incorporated the maximum valvoa.
That's not a card, at most it's a routing!
What's in the hydrofoil block? and the auxiliary distributor? and in that of the lifter?
valve calibration? specific valves?
Otherwise it's more likely to get rid of us by looking at balls (glass)
Unfortunately I do not have all this experience, it was more an attempt on an old tractor. Does it work? it is more than a year that I use it so and goes everything, the only problem that I respond is precisely what when the pistons of the lift go at the end of the stroke the pressure of the oil tends to return on the piston of the hydroguida making slightly sterzare the wheels. the hydroguida is the classic one mounted on the carraro with a built-in maximum valve, the auxiliary distributor has an output with carry over and a normal and that of the lift is a simple distibutor.
Well...
can be a problem of a "wrong" component as well as something that "does not work well", in the sense that a component is defective/weary and generates that abnormal behavior.
If you do not enter numbers, the calculator does not give you the result.
without having more information what can we tell you?
