duration
  • Thread starter Thread starter preben
preben
is there no possibility of knowing the length of processing of rendering? not as much as is missing at the end (among other things is always there?????) but the time spent since the start of the process? allego window that I do not understand durata.webp I looked in red. Thank you.
3ds tells you the time spent for the last render done (and completed) in the same rendering session.
If you closed and then relaunch the trial puts???? ? ?
Then it is as I had understood....the fact of the instantaneous chronometer of rendering is not there. Thank you
