salierno.emanuele Guest Oct 28, 2015 #1 hi to everyone, I went to autocad 2015 but I have a dwg visualization problem. I can't understand what they are and how you disable all these lines on the dwg. igo photo. . thanks to all Attachments IMG-20151027-WA0004.webp 17.5 KB · Views: 7
tir Guest Oct 28, 2015 #2 use ttf fonthttp://www.cad3d.it/forum1/threads/45557-problema-stampa-pdf-con-font-in-formato-shx
salierno.emanuele Guest Oct 28, 2015 #3 hi tir, my problem does not refer to the conversion dwg to pdf
PlannerRoad Guest Oct 28, 2015 #4 salierno.emanuele said: hi tir, my problem does not refer to the conversion dwg to pdf Click to expand... tir linked that link to make you understand that it is a font problem used.
salierno.emanuele Guest Oct 28, 2015 #5 Guys I solved, the problem was hardware acceleration. Good day to all
