dwg editor: print style
  • Thread starter Thread starter czar
czar
I'm the only one who doesn't understand how to set up the print style? It's been a while since I've changed some parameters but nothing changes here:confused: ....is there a tutorial? no because when I go to the question mark, it tells me there's a file missing and so no guide....:mad:
I'm sorry I didn't answer you, but I don't use dwg editor. I used it a bit with 2007 but then I took autocad and abandoned it. Are print styles not equal to autocad?
I'll take it.
you are about the same. the problem was another: you have to specify the path in "options" and then "percorsi/files"....I kept creating the style and then put it in the same folder where there are all the other print styles....peccato that it was not the indexed folder....
