dwg of solidworks erroneous line scale
I have done so by removing the hidden purge in fact you see right .cmq even if you remove hidden autocad puts it back every time. But I don't want to use the hidden style "beared solidworks and force that of autocad x of the restraints that I can edit ... then it would be a slaughter since the file on which work already has the hidden line of my model ...I read that on the original design I could rename the hidden
What does that mean? autocad to capricious while you draw continuous lines you invent a hidden style?
But I do not want to use the hidden style "wrong solidworks and force that autocad x of the restraints that I can change ...
Then stay as you are
I mean, the hidden line is back every time. I gate it from the dwt unless I restart a new design I choose my dwt and always appears hidden .maybe because I have the English version ...
You're blaming, or motivation, the most devastated things... is mechanical, and in English.. as if this had something to do with the functionality of the program, as if an Englishman was more or less avanized than an Italian or a Japanese.
you after deleting the hidden line save and overwrite the dwt or save a normal dwg and hope that after doing it 30 times autocad will understand by itself that must eliminate that style of inea from the model?
also you eliminate only the layer that contains the hidden line style or eliminate even the hidden lilea style?
who creates the hidden line even if the gate?autocad:).in Italian there was no problem since there will be the line called hidden and not hidden .
no no I except the dwt .io eliminate the hidden line going in line types and I delete hidden .salvo reopen the model and find myself hidden .non understand .
in this case the problem is that mechanical automatically generates the lines that are used for automatisms (parts library, calculations, symbols.... )
doing the process with autocad, both Italian and English, the deleted line styles do not reappear.
I have no idea.
the loopholes can be:
-create an templat starting from the dwg generated by solidworks
-manage the ltscale for each design by evaluating the representation of the lines
-use paper/layout space
Okay thanks to this I wanted to get there, important is to know why. I don't want to change much, I change the type of line
If you just want to make an attempt to uniform the situation is this:
open the dwt
Launch the amlayer command
change the layer line hidden from hidden to continuous
do purge, check that there is no hidden line and save the dwt (for proof open a new dwt and check that there is actually no hidden line)
open solidworks design
copy the hidden line in the dwt (display should be correct, attentive to ltscale)
reimposti the hidden layer with the hidden line
purge and save dwt
do the final verification by copying the solidworks design in the model
open the dwt
purge and save dwt
Thanks for the patience you had. . .
