snorky
Hello everyone,
I have the need to "quote" distances on the z axis, for example I have scattered points and instead of using the "dist" command I would like to use a dynamic block containing 2 points, two moving actions and an attribute with the necessary formula, like this:
<\cobjprop.16.2 object(%<\_objid 1649756076128>%,1).coordinates \f "%lu2%pt4%pr2">%-%\acobjprop.16.2 object(%<\_objid 1649756076144>%,1).coordinates \f "%lu2%pt4%pr2"%
in which I take the quota z of the first item and subtract the share of the second item.
except the block and the text....
I load the block, move the lock points on the points of my interest (which obviously have different coordinates z) but the block points remain "fixed" on the "zero" plane preventing me from "measure".
Where am I wrong? must change approach? other solutions? Thank you!
