Giuseppe Beatrice
Hello, guys, I have a little problem to expose you.
I copied a drawing portion containing dynamic blocks with attributes in another design, with the command "copy with base point". . and all the blocks with mirrored attributes, even if in the design of origin they appeared correctly (variable of system "mirrtext" set to 0), instead appear inverted on the design of destination.specific that even in the target design the system variable "mirrtext" is set to 0.
Moreover, I have already done this many times without finding the problem indicated.
I finally add that the above command ("copy with base point") gives me the same unexpected result even if I take off the copied block on the same design of origin!
Is there any other system variable I don't know to check?
