dynamic curve display on 3d map
  • Thread starter Thread starter telescala
telescala
Hello everyone,
I'm a field mole, but I have a problem to solve, so I'd need some tips to figure out what direction to start moving. I started reading about gis material, but the subject is so wide that I struggle to orient myself. could you give me a hand to understand what to study and what programs to use, so as to optimize the working time (unfortunately I don't have much available) to achieve my purpose?
I ask you the problem:
I have the need to create a stand alone application or an application to be inserted in a web page to be displayed offline, showing a map of Italy in 3d within which to move in a mode similar to google earth and properly modified in such a way that to display dynamically in some areas of space, identified by geographical coordinates and altitude, markers or better of the color zones that correspond to a mapping obtained from values stored in a database. Precisely that the application should be used for commercial purposes, so I must be able to get all the licenses of the case.
Where can I leave? what tools can I use?
thank you very much in advance for your availability and patience.
Reinvent hot water? Why do you do it all over again? lean to google and develop only the necessary piece for your purpose!
thanks tristan,
but from what I understood google does not allow the use of bees for commercial purposes. Am I right?
