Yansulu
I designed a small microcontroller-based device that implements a firmware for solving the problem of the reverse pendulum.
Before embarking on its construction I would like to simulate its operation in a virtual environment also to test the goodness of balance logic.
I know that in solidworks there is the possibility to simulate the movement by setting a function, but my problem would require to set up a virtual environment where the object should be subject to gravity force and I should be able to run the firmware somehow (for example linking somehow solidworks to mplab....I don't know...) getting a more truthful dynamic simulation possible.
I ask if something like this is possible in solidworks and if it is not what software I can use.
