dynamic ucs
  • Thread starter Thread starter iron72
iron72
Good day to all.
Now after building my basic geometry I created a region and extruded it, then I moved with my x0,y0,z6 axle and then I rotated the x axis of 90 degrees.
I built a profile and then I erased it, because it wasn't good.
ok only that now I would like to build another geometry of support to the first in 2d, I clicked the icon of the global variables, the axle is back to its place, I placed the view from the top, only that when I go to draw, then select a geometric element, like the line, the pointer changes and becomes similar to the axle terna and therefore I can not position correctly in 2d.
how do I restore the axle-like pointer so that it becomes usable for the 2d?
p.s.: place here the file.
you are not very clear in what you cannot get!
What do you have to do from your basic geometry? Why do you use the 3d first and then you want to delete it?
try to click global ucs, the one with the globe.
I have already clicked the global ucs but has no effect.
I attach here two jpg files to see what happens to the pointer before selecting a geometry, in this case a line, and after selecting it.
as you see the pointer is no longer cross with the white square in the middle but it turns into something similar to a three-dimensional axle.
disables dynamic ucts
Okay, Tristan, that's it.
only to understand, but the dynamic, selected ucts, enters into operation in this mode only when a solid is built? and then in practice what is needed?
automatically directs the work plane to the face of the solid on which stations; utility is dubious, in theory it is necessary not to pass manually from one ucs to another, but it works maluccio and it is good until you work on cubes
