eat bucare a wall
  • Thread starter Thread starter com_che
com_che
Hello everyone, I have two small problems, as you can see from the image, the colored wall in orange should cut it to the height of the green one, without having to make two walls with different heights, how can I do?
the red circle instead shows the scale, which at the moment penetrates the wall and in the loft, instead it is the loft to adapt to the scale, I should cut it? and for the wall how do I interrupt it under the scale?
ciao,
the wall colored in orange should cut it to the height of the green one, without having to make two walls with different heights, how can I do?
select the wall, in the properties it breaks the height from the floor and hand-signs it (or aligns with the appropriate command).
Should I cut it?
sagomi the perimeter of the ceiling on the arrival of the scale
and for the wall how do I interrupt him under the ladder?
reference floor padlocked at the bottom of the staircase and attach the height of the wall to the floor. But first you should divide the wall into two parts, under the scale for one part (the one to associate with the reference plane) and the other to associate with the loft and then join them (with the command).
I know...for the knowledge that I have in revit...that however to adapt the wall in orange you have to change its settings from the property panel
