Eat chiudereste questa surface?
  • Thread starter Thread starter peppo82
peppo82
Hello, gentlemen, come back with a new problem.. .
attached there is a file of an exercise that I am doing to sprat me a little, is the surface of a combustion chamber on the head side, modeled very much but very good :-)
I have a problem, which I hope someone can help me solve, I would like to close the open space with a filling surface, but there is no! the blend surface should work, but from what I understood, while on the exhaust side, the blend surface that uses the spline fits perfectly to the flat surface that constitutes the pertinence zone of the exhaust valves, on the suction side, the same surface, obtained in the same way, does not attack you, in fact when I use the shift button to select the chain the perimeter that I intend to close, they are evidenced red of the edges that really should not belong! ! !
Please help me, tell me how you would close, answer me even if you would advise me to act completely differently, what I need is above all a feedback from who is the master of the subject... please! !
Unfortunately the part you have attached was created with a didactic version of creo 2.0 and with the commercial version
You can't open it.
jambo
