edit text with 2015
  • Thread starter Thread starter Tarkus
Tarkus
Hello everyone, :biggrin:
with versions prior to 2015, to change a text, just double-click the text and automatically open the "_ddedit" command in the case of single-line text or the "_mtedit" command in the case of multiline text.
with 2015 double-clicking on a text,the thing only works in case of multiline text, in the case of single-line text, appears the writing that the command "_ddedit" is unknown.
I must then open that text through "properties" and change it or use the "modtext" command.
It's a long time.
but then, if the "_ddedit" command no longer exists in 2015, why is it automatically launched from the double click?
is there any chance to return to how it was in pre 2015 versions by automatically using the "_mtedit" or "modtesto" commands?
I hope I've been clear.
can not change the action of the double click in the .cui inserting in the single row case the right variable?
OK works. :36_1_11:
I would never have thought that in the .chei there were also click actions and other mouse actions.
thanks for the right
