effective roughness cam machining
  • Thread starter Thread starter rinato
rinato
Save to all, by chance someone performs tests/checks on the actual ridge height resulting from 3d machining in which he set it as a "guide" parameter of the processing step?
I should mill surfaces in 3d with the bond of roughness (in theory ra) not pushed: Let's say, standing on top of 3.2. but the ridge height in the cam is not ra (perhaps rz?) . so I wanted to understand that paramentro set, p.e., with a sup. type horizontal cylinder ø35 and ø10 spherical, ideally worked with the "parallel plates".
of course I have no way to do tests on the final piece; At the most, I could make "tamps" to lose in small dimensions, x check the result.
thanks for any info,
Rianto.
in cam environment and in strategy options when choosing the step comes out the theoretical ridge, otherwise you can always draw it and see the resulting.
hi, I forgot this post.:sleep:
Yes, I did some graphic tests, even saving and analyzing for points the stl resulting from the simulation.
then the real piece was "Russian" as required and worked well.
Say hi.
