elastic bearing compensation ring
  • Thread starter Thread starter franksan87
franksan87
Hello.
I use proe wf 5, I am not very experienced, I would like to ask if you kindly can tell me what function to use to draw the component in question, and if you explain how to do it best.
thank you so much in advance for the help!
Hi, frank.
the best method is a variable section sweep with the inerno of relationships the function trajpar.
I attach a file so that you can check in the vss section sketch reports as it was written.
cminhabiting the height parameters and undulations modifies the model the diameters change them from the sketch.
the trajpar function serves for many other things... I suggest you study it well.
Hi, frank.
Thank you very much ptc, in fact the trajpar function is very useful, I had already been reported in a discussion with the same name of this, unfortunately wrong I generated two discussions with the same title and I failed to eliminate one.
Thank you very much for the courtesy and for the file, so I got to confirm what I did.
I have joined the two discussions and eliminated the double message of introduction.
