IlNanni
I have to do a modal analysis of a tree with attached a rotor; I need to simulate the constraints that represent the bearings at two points of the shaft. I thought of simulating these constraints with some elastic support but I can't understand what value you have to insert rigidity, which is reported in n/mm^3. such value is called foundation stiffness. the guida riporta:
the elastic support is based on a foundation stiffness that you set in the details view, which is defined as the pressure required to produce a unit normal deflection of the foundationif someone has a suggestion thank you in advance.
