elbows and sheet thickness.. .
  • Thread starter Thread starter GiGa
tarkus I attach the native file to you, in this way you reproduce the processing of lasertube, although in some situations it is not very truthful (cut to degrees)
I hope it can be useful!
I see.
curious, you didn't use surfaces but you thickened your face inside the tube, effectively eliminating the thickness of the initial extrusion and creating a hybrid object... but as you say, it's not true at some point.
in fact that process has limits, it is enough to consider them in the phase of modeling. However the limits are justified by the little time necessary. with the rhythms we have here in the company I could never use the time necessary to do it with the surfaces, I would make a fool! :
I actually use that method only to realize the final result of laser cutting (in the modeling phase), then the final 3d model I leave it without the thickening, otherwise the laser cam makes the whims.. .
