electronic sheet
  • Thread starter Thread starter glisman76
glisman76
hi to all boys this is the first time I write on this forum , I would like to learn how to use think3 2009.3 and I wanted to know how the electronic sheet worked to create an anomaly , the exercise I have seen it several times but I can not make it work on my project concerning the geometries of a model radio remote controlled engine burst, I hope someone can help me
thanks in advance to all
parts from simple things, like a cube:
make an extruded profile and assign to the extrusion variable a variable
in this way td creates an electronic sheet variable.
then go on tools -> animation
below you should open a window to manage animations
right button on the animation pane-> add
right button on the evolutions -> add -> variable .. here select the variable that has just created you
right button on variations -> add
right button on the newly created variation -- here set the values and the game is made ..
This is a basic thing.
if you need things + specific faces of concrete examples. .
Matteo
thank you so much for the advice but excuse the question how do I insert the variable to the extrusion?? ? I'm sorry, but I'm not so practical.
simple,
during the extrusion, before confirming the command opens a casellin where you can enter the extrusion value.
If you put them in there, for example the letter "a", you automatically generate the variable in the electronic sheet.
If you've already done the extrusion, you'll be redefining it, and with the same system mentioned above you get the desired behavior.
There are other ways, but this is the + simple one.
if you want to deepen the topic I suggest you open the online guide "?"->guide online and search for the following keyword "exercise: electronic sheet"
hello and good weekend
Matteo
hello matteo thanks for the advice, but the animation I seek is not so.
we say that I would want the cube to rotate by 45 degrees looking at it frontally but I can't make it rotate.
listen if I send you the file that I did you could tell me how I can rotate the suspension bracket by 30°
test with the evolution of the camera,
you can define a path and a tag.
the camera will follow that path pointing to the tag..
If you can't, send me the file.
Good night, bye
Matteo
