elements in group
  • Thread starter Thread starter Putrella
Putrella
Good evening, everyone. . .someone can explain to me why the cutting of elements compared to a reference plan is not extended to all groups of the same type?
I tried to look for such a discussion but I didn't find anything!
thanks to all:rolleyes:
Could you give us an example?
I make a metal portal, I create a group and I modify it (cut the beams of the portal according to reference plans to create the joints), I copy it to the successive wires and in those copied the modifications I made there are and there is the original portal..:eek:
but the reference plans do not apply on the whole project? should be absolute. Besides, I guess a group is like a block.. I'll change one and change everyone regardless..
true, however, in this case, you modified the beams using the reference plan. So, that plan must be added to the lump.
