juli
hi..scusate....I wanted to know how to put the elements like walls or even ceilings in transparent i.e. that you see only the edges....I hope to be explained. . .
..I need lines drawings but only some elements not all design....Do you mean iron fl or lines?
for the iron fil of changing the engine settings (it seems to me in the display menu), to have the lines drawings of saving the 3d as .2dl after setting the internal motor
....ehhhhhh????you have to make more views then and then overlap them with lines
...:finger:in archicad there are various engines that allow you to view the elements you draw in different ways: iron fil, with pastel colors, with textures etc. but you can not have a view a bit of iron fil and a bit to lines.
But you can save a 3d view realized first with one engine and then with the other and then work with the parts you need, or save a view and then delete the retini that you don't need
