dragonix
Hello everyone,
I have to check through fem a steel structure (a workshop bench).
the structure is of fe 510b. I had a doubt about the admissible tension to consider.
the Norman uni cnr 10011 proposes, for calculation to the admissible voltages, an admissible voltage of 240 mpa in front of a yielding voltage of 355 mpa.
next to this rule there is the eurocode 3 for the design of steel structures: Does this rule apply only to structures for civil use?
in the mechanical design of structures like what I mentioned, what tension should we take as reference?
Thank you for the answers
