elimina filtri layer in batch
  • Thread starter Thread starter lorececco
lorececco
good day, I would need a utility for deleting layer filters from a large amount of cad files automated, so as not to have to open them all in succession. thanks in advance
Seems interesting, thank you. The only fault is that it costs $75... other cheaper ideas?
this is the lisp to delete the filters on the layers, to be recalled with appload, does not create any command, simply deletes the filters.
this is the xls file to create scripts, The script creams, attached the file to be recalled within the script.
I mean, you have a problem but you want the solution at all costs for free.
thanks to @rpor66 ... if it were for me along with the lisp I would have sent you the invoice
Of course I do. I'm sorry, I didn't want to offend anyone's sensitivity, I just kindly asked for help (not being an expert on matter) since a purchaseable solution I had found her alone.. .
Usually the spirit of a forum is to help you solve problems, right? It seems to me @rpor66 I interpreted it the best way! for my part now I will try to understand how to create the script to use the lisp, and I assure you that for me already this will not be trivial. . .
Have a good day
Yes, yes! but since it has become customary to subscribe to the forum, ask for help and then disappear into nothing, I put my hands on. We will see in the future how much you will help others.
a good day to you
