elimination of internetration
  • Thread starter Thread starter Stanix
Stanix
Hello, I am designing the vault of a garden oven, and I have the following problem in assembly
created the geometry of the parable style vault, you have to close everything with the classic full bricks.. Is there a way with proe 4 to "cut" the brick pieces that once placed go intersect the vault?
an alternative solution I think is to go to create a "part" from all the bricks placed, and then go to make a beautiful extrusion by removing excess pieces following the trajectory of the time... but ahimè do not know how to extract the part in modalita assemble.. .
Thank you so much!:confused:
usa operations with components, find the command under the change menu.
in this way make a cut with the vault on the bricks.
thanks a thousand max for the celerity of the answer... .
but there's something wrong.... so... under the menu operations with the components I can make copy, mod insertion, reorder, group, merge, removes and transform.... I think it's the merge command.... but once you ask me to select the / components.... nothing really happens =(more
How can you make me feel like a jerk? Even the star-cd had never managed!
once again thank you :) I look at the example, even xkè I found on the help a good example nopn played called "material removal by joining parts" and not even images how rosikando xd
cmq not demordo! !
