eliminatione connection lines
clark85
Hello everyone,
use solidworks for a couple of years (now I have 2015 sp4) and now I decided to try to solve the following problem:
When I go to put on the table and quota the holes obtained with the linear repeat command, it always puts the hateful lines of connection that connect the holes/shades.
regularly the helimins but generally puts two overlaps so there is a discrete loss of time (as well as breaking of bales!), so it always touches me to eliminate them all and put only the centering pockets with the appropriate command.
Is it possible to avoid automatically putting me those hateful lines?? I looked a little in the estate but I didn't find anything! !
help?
simply quotating does not put the lines of consignment.
then you should specify howr you put them.
if with the centering notches is one thing, if at the insertion of the views is another
the lines are automatically put by solidworks when I insert a view, usually then the elimin and I put only the notches
then go into the property of the document>scheda details and see the spuns to be removed.
