GiGa
I created a couple of models with several variables managed by ilogic (by the way, it is a bomb! try it!!!). . .
These are pipes for which, according to different diameters and corners of curvature, vary flanges and various sizes.. .
changing a few values, of course the model updates accordingly... the "problem" is how to change these values.. .
the easiest way is to make the interested sketches visible, but so I should hide them every time I use them in a set.
Another simple solution would be to edit directly in the parameter list, but you need to search for values between a dozen parameters (not very convenient, unless there is a way to reorder them). . .
I thought of creating a form in vba, but I should take the part of "programming" vba but now not time to do so.. .
Is there a "rapid" way to vary some values in an elegant way?
the ideal would be to be able to display only the editable quotas, but only within the part, without having to "send them" at the moment of insertion in the axieme.. .
