Aretering
Hello, I should make a functional design of a planetary kneader.
I need a particular mechanism (gearbox) that converts the rotation of the shaft connected to the motor, into a planetary movement out: that is, the output shaft must rotate beyond that around itself, even around the axis of rotation.
to mean something like this: https://www.youtube.com/watch?v=zjdryd-dpnmI've got the door and I've got the satellite axis.
the question is: you know how this device is called (I tried with planetary gearbox, but I find mostly standard epicycloidal gearboxes)
because I would need a catalog of a manufacturer to choose the one suitable for my needs.
grazie
grazie
