equation, bonds in vba solidworks
  • Thread starter Thread starter titurbina
titurbina
I have the need always in vba of solidworks to insert a bond equation between the diameter of 1000 mm of the sketch 1 (frontal plane ) and the 500 mm share of the sketch 2 (upper floor) from the figure below to the right (in Annex ), so that when I change the diameter in 800 the interested share becomes 400.
thanks.:smile::smile:
It is true that it would be enough to put the bonds in solidworks before doing it in vba for solidworks, it is that I am encountering problems being on two different planes and sketches.
Is there just an equation because in vba?
create plans/axes that satisfy the second sketch's relationship with the first and make the second sketch coincide with these references.
