malamente
My wf2, when defining an equation curved datum, refuses to open the notepad on which I should type the parameters of the equation itself. I came to the point where the dialogue panel tells me:
sist. coord. defined
type siscoo defined
required equation
After that, a black-backed window opens for an instant, closes and everything stays so suspended.
the command line below says: "all elements were not defined. select elements in the dialog box." But if the previous elements are defined while it does not allow me to define the parameters of the equation automatically opening the dialog box, I don't know what to do anymore.
in the browser I open with the info button of the dialogue panel, the local parameters of the curve have a field in which it is written "access :locked" and "designed: no".
Some straight?
Thank you in advance.
type siscoo defined
required equation
Some straight?
