andrea.boerio
greetings,
does not exist the possibility to bind quotas to others through relationships that are not only constraints? I would need it in the context of empty views, in which I have to insert sketches, possibly then to turn into blocks (but it is not said). I don't see the equations.
example, I want to draw a rectangle where the base=2/3* height, or insert other less trivial parametric dimensions. or again, pilot the value of a share with a global variable or a custom property value.
would all be very trivial in part environment, but at the table how do I proceed?
It seems like a castronery, but I swear that it happened very often, with other software, to exploit these possibilities of two-dimensional design evolved, especially in those cases where you did not necessarily want to create a part file.
Hi, a.
Hi, a.
