equations in conjunction with boolean logic if/then if then to make automatic choices: possible?
reggio
equations in conjunction with Boolean logic if/then if then to make automatic choices: possible?
hi, I would need to create some parametric assemblies, to understand with a simplified example we would have
part1 = sketch1 + extrusion1
part2 = sketch1 + extrusion1
part3 = sketch1 + extrusion1
part4 = sketch1 + extrusion1
together1 contains part1,2,3,4
What I want to do is
from inside to together1 (or excel table?) change by hand the part1/extrusion1 measurement and get automatically that
if part1/extrusion1 <=10 then part2/extrusion1 becomes 700mm
if part1/extrusion1 >10<20 then part2/extrusion1 becomes 800mm
if part1/extrusion1 >=20 then part2/extrusion1 becomes 900mm
... then if possible also:
if part1/extrusion1 >30 then suspend part3 + active part4
Can you tell me if it's possible to do it with sw21 and in case I can do it?
It is not a trivial thing, but it can be done
it is pleased to solve a problem with a single post.@reggio , if you can attach a trace of how you managed it would help future colleagues
the excel sheet as well as having columns referring to the variables of the quotas can also have the reference to the features suspended or not.
on the fact of suspending the parts I never did but I saw once in a demo of solidworks that you can do.... already 10 years ago....
