Equations on functions.
  • Thread starter Thread starter serbring
It is not that I did not want to give my model, being a thing created by me from scratch and being a simple mechanism I can do the upload without problem, here in the office I can not do the upload since the hosting sites are blocked and then I should have waited to come home in the evening to do so.
for this forum hosting sites do not serve, on the contrary it is deprecated use. there is the appropriate function to attach files (the native cads must first compress them with various zips, rar etc.), you find it in the same window where you write the messages.
another advice; explore and test well All menus and all program functions. click everywhere, left and right (mainly, there is under a world)... test and test, even if "wrong" something does not happen, but that's how you learn to know the softwares. read the guide and all the help (the questions) you find in the various property managers of each function.. At the end you always get there.
go to see the menu options as it is set; change and test All the settings available, so you understand "how to reason" the software.
Mar
in many forums you can upload only 250k and so I didn't look at it.
Mar
You're right, sometimes you just need precise tips to understand the philosophy of the program. However now I have finished my model and imported it into virtual.lab which is supported by caia, I hope in good results of my simulation :)
thank you all
I find myself writing to you again because I had to make changes to geometry. In particular, I have a scissor mechanism and I have to place it in such a way that it is mid-race. in this position I have to horizontally make a cross between the two arms. I can't understand how I have to insert the constraints to make the horizontal crossroads sketch. I tried to move it by hand but as I have to have some restraints compared to other bodies of the same part, I mess up everything. Then I tried to introduce in the same part a new reference system that is oriented like that of the axieme, but I can not impose the constraints between the reference system and sketch. the copy/seat command does not work because I should only rotate a function. other advice?
Thank you very much
