error after printing in pdf with autocad 2000
  • Thread starter Thread starter gianlucap
gianlucap
the problem that always appears to me with 2013 is that if a design the mold in pdf and then save it after printing in pdf, at the next reopening it gives me a lot of errors, it happens to you too?
.... another problem that always appears to me with 2013 is that if a design the mold in pdf and then save it after printing in pdf, at the next reopening it gives me a lot of errors, it happens to you too?
installed the service pack 1.1 of autocad 2013?
What pdf printer do you use?
tried to print with other pdf printers?
Wait, but is it autocad that gives you errors or the pdf file that presents anomalies?
the autocad file gives me errors, like I don't get the part list anymore, I disappear the details and other things, however I try with this printer then I deceive you.
As for the problem of fast keyboard controls, do you know how I can solve it?
Are you talking about autocad or autocad mechanical?
autocad machanical. the problem is both on the 2013 and 2011 version, despite installing all the service packs on both versions.
So I tried to install bullzip pdf and it works, the problem is no longer there, but I have to print it, not export it, because at the time when I take the problem there.
Can it be my problem?
So I tried to install bullzip pdf and it works, the problem is gone, But I must print it, not export it, because at the time when the problem arises,
I don't understand.
must you print it on paper or create a pdf?
I don't understand.
I have to create a pdf.
So, after drawing in dwg, I have to create a pdf to send to the customer.
in theory you save the dwg design and then you convert it to pdf.
often happens that going in a hurry, finished the design converts it immediately to pdf and then save the dwg and is then the problems arise.
If the drawing takes it out in pdf and then save the dwg file at the next reopening it creates a lot of errors, while if the mold with bullzip and creates the pdf and then save the dwg file there is no problem!
However with the 2008 and 2009 version this problem I never found it.
I hope I was clear with all this round of words.
have you tried with cutewritepdf? creates a virtual printer that makes a drawing directly in pdf
no, I tried with the one recommended by planner and it works, only if I mold the design in pdf, if I carry it in pdf it gives me error.
but do you use mechanical find yourself with my own problem?
