error ansys
  • Thread starter Thread starter Seiya09
Seiya09
Hi, I wanted to ask you:
when using the command resolves in ansys, I do not get out of solution is done and in the output screen, the following error comes out
"a small equation solver pivot term has been encountered at the uy degree of freedom of node 720. ansys has automatically constrained this degree of freedom. check for an insufficiently constrained model."
I don't understand what that means.
Thank you all for helping me
He's telling you that you have a labile model... recheck the constraints, and also check what's wrong with Node 720. also controls connections between elements
