Braindrop81
hello to all
I have a problem with the cam of visi 12.1 when I go to post process there appears an error message : the .mtg file is not configured to generate the rotation of the required axis ... then the fie with the machine code that comes out is practically empty if I choose the heidenhain and instead it seems normal if I choose the fanuc ...idee? ?
the prob is that I need a machine file with heidehain control
I forgot to premit that I'm at first with the visi cam ... where I worked before I used caia ... we hope to learn at best in a short time
greetings and thanks to all
