error displaying a curve on creo 2.0
  • Thread starter Thread starter Virgundo
Virgundo
Good morning to all,
I have a problem about creating a sweep using creo 2.0.
I would like to create this particular that is not another aluminum profile that then in reality is fallen.
IMG_2331.webpso I proceed like this:
- amount drawing sketch from a .dwg file;
Primo Sketch.webp- I open the sweep and create the trajectory that is nothing but a ray;
Inserimento traiettoria.webp- and practically as you can see from the photo the curve comes out all spigolosa;
errore 1.webpYou know where I'm wrong? the error is given to me only if I use it as a display option "shaded with edges" because in case I go to choose another option that is not "shaded" the errors are not there.
Here's the picture.
errore 2.webpI thank you and hope I have not broken any rules of the forum.
stefano.
the edges you see are exclusively due to a graphic approximation of the shading.
if you increase the quality of the shading (maximum value 10) you will notice an improvement of the representation.
Bye.
Thank you very much, sir.
I solved, I realized I have always worked with a shading quality value of 1 :censored:
