error if2020 "impossible to complete the operation because the folder or file in it is opened in another program" on server windows
  • Thread starter Thread starter migale
migale
cartelle.pngSometimes this error happens when you try to rename a folder (or delete it) on the drawing server. the operating system is windows 2016 server... Do you have any idea how to solve this? or is it a problem inherent in all microsoft os (before we had a basic linux storage and did not happen)?
windows does that when, even with no open files, there is still a program that made the last save in that folder. i.e. windows prevents deleting the "present working directory" of a certain application, provided that the application is still open obviously. next time you happen try to save or upload from a different folder than you want to delete, and then try to remove the folder.
It's not a solid edge kiss but a "feature" of windows, which in this sense is much more careful than linux where you can safely delete an open file and no one will tell you anything. :
Of course, that's a window problem more than a solid edge I suspected... ;)
But then would you say that "would" close solid edge on the incriminated machine? Yet some colleagues in the past told me that he couldn't delete/rename a folder even after closing the program.. .
Sometimes, but opening a file from another folder is even better. sometimes it is a problem simply of previews (small bitmaps) that at windows are still open. In the past, sometimes I had to try again the next day or even restart the server, but sincerely, it's so much that I don't happen anymore.
