error in loading two lisp
Angelo2449
Hello everyone,
I can't load two files > .lsp < that normally loaded with > appload <, the two files work perfectly.
the code I try to upload the two files is this:
Code:
 (load "c: / as / lisptre / areari.lsp")
(load "c: / as / lisptre / graficarill.lsp")
the two files are of course in the indicated folder.
the same command, for loading other files (loading from acad.lsp), works fine.
What's going on?
I follow the post,
if I run the same commands from the autocad bar, everything works!
I go to memory:
test with double bar.. .
(load "c://as//lisptre//areari.lsp"
or with the bar backwards
(load "c:\as\lisptre\areari.lsp"
or with double backwards
(Translated with Google Translate)
