spilladabalia
Hello, everyone.
I am meeting a problem in making a very heavy scene, with mental ray, 3ds 2009.
the render will have to be very big, but trying to 2362 wide, which is not then much only appear white dots and a series of error messages that, forgive me, cop and neckline:
rc 0.3 error 081001: failed to create frame buffer 0: d:\docume~1\admini~1\impost~1\temp/fb000.9.4932 (insufficient reminder to run the command. )
img 0.3 error 101003: : can't create files
rcfg 0.3 error 541001: failed to create frame buffer 0: d:\docume~1\admini~1\impost~1\temp/fb000.10.4932 (insufficient reminder to execute the command. )
rcfg 0.5 warn 542002: angle between normal and geometry normal > 90 degrees
rcfg 0.4 warn 542002: angle between normal and geometry normal > 90 degrees
rc 0.3 error 081001: failed to create frame buffer 0: d:\docume~1\admini~1\impost~1\temp/fb000.11.4932 (insufficient reminder to run the command. )
rcfg 0.3 error 541001: failed to create frame buffer 0: d:\docume~1\admini~1\impost~1\temp/fb000.14.4932 (insufficient reminder to execute the command. )
rc 0.3 error 081001: failed to create frame buffer 0: d:\docume~1\admini~1\impost~1\temp/fb000.15.4932 (insufficient reminder to run the command. )
It's a scene in perspective so I can't make it in two pieces.
Can you give me some advice?
Thank you in advance!
