error of incompatible units
  • Thread starter Thread starter Antares89
Antares89
I'm creating a parametric project. with algorithms imposed a frame data and thanks to the chassis generator I get a file that fits according to my needs. the program in the 3d environment works perfectly.
Unfortunately, I have a compatibility error in the list table parts. in particular the program sees two pieces of the frame that are identical, group them in the same number but instead of indicating the length of the pieces writes me error of incompatible units and puts me a good warning of error in the browser. the best thing is if I go to open the distinct components the measures that should be incompatible are equal. it didn't end here, if I change the parameters of my structure this error sometimes disappears sometimes comes on different pieces.
I would like to know if any of you have a solution to this error or precautions to avoid it. Meanwhile when I happen I go to manually change the cell by imposing that measure you know but that according to him is incompatible.
Thank you for your attention
