error: selected element not connected to solid multisection
  • Thread starter Thread starter ManuelaC
ManuelaC
Hello everyone!! !
I'm at first with catia and I'm trying to draw a helical gear.
I designed the two profiles on two different and parallel planes, but when I go to use the solid multisection function I give the error lying in the object only on a sketch (there is to say that to make the second sketch I used the function "project 3d elements" so in theory the two sketches should be equal ---> the error appears to me on the starting sketch); It also tells me that I can extract the entity connected with the near operator, but I don't know exactly what it is! !
thank you all,
Manuela
