error tolerance
  • Thread starter Thread starter valeria_emme
valeria_emme
Hi, I'd like to ask for what reason by putting a concentric tolerance, I'd like to see myself out of "non-valid type specified for tolerance"... I don't understand... place a jpg
It can be that you have defined the axis with the same surface you want to tolerate, it could be a "authorized" tolerance.
try to define the axis using a different surface.
Oh, no. The axis has nothing to do with... I have a wrong perspective and maybe you have to...
I see two possible problems, at least if I understood the image well:
1) you have put as a reference surface the lamatura and as a superifice reported the axis of the hole, if anything had to be done the opposite
2) you are trying to geometrically tolerate the position of a theoretical axis, but this then in the test of the piece would be impossible to verify, since this axis does not exist in reality. try to select two surfaces instead of an axis and a surface and see how it goes.
no:36_1_4: I always have the same error
that error signals to you before selecting the surfaces.
this because it is not correct to indicate the value of a concentric/coaxial tolerance in that way. the note is assigned the same, but in the tree remains an error signal.
concentricity/coaxiality is indicated within a "circular field", then in the value box you must prescribe the symbol island island. try to do it and you will see that the message below disappears.
your annotation should be like this:TOLLER.webpif you want to indicate the "radial" shock you must use the symbol circular oscillation (the one with a tilted dx brake) instead of concentric.
Marco:smile:
.. in this regard (but not only) consults the baldassini in paragraph tolerances.
If you didn't get it, you'll always be useful.
Mar
in the value box you have to prescribe the symbol island island.
:36_1_11:
ok... anke if in theory the diameter do not go xkè the circumference is visible... cmq now gives me no more error... I managed to do as you indicated (the only difference my reference is rested on an arrow, your directly on the surface, and I don't know why...
I tried to spend the whole thing at the 2d... amount of the notes, but nothing... for me it is not a rewrite problem, but I kiedosk if the fact that they do not automatically appear is index of an additional error:confused:
:36_1_11:
ok... anke if in theory the diameter do not go xkè the circumference is visible. . .
No! here it takes the ø. has nothing to do with quotas (even if you have learned that even there is old norm and the symbol you can always put); is a geometric toll and indicates that the axis must remain contained within a "imaginary" cylinder of diameter 4 cents. It has nothing to do with circumferences in the model.
Mar
No! here takes the ø
Okay, I don't argue. . .
But why don't you put the tolerance on the table automatically? ?
...and why (just noticed) this huge pink tolerance, always remains in the foreground and does not appear only in the click on the tree as for all other odds? ? ? ?
Sorry the question... but why do you not put quotas and tolerances directly in 2d? What advantages are there to put them in 3d?
for the speech geometric tolerances quoto sampom, the fi is to indicate the imaginary cylinder that must contain your axis!
I have to share them both... quotating the 3d and then passing to the 2d inserting all the elements of the model, vien out everything automatically... except for tolerances... for me it is not a problem to put them back on the table, but I kiedevo if the fact that they don't come out automatically means that I made something wrong
