error when reading the template file
  • Thread starter Thread starter romi
romi
Good morning, everyone.
as from title at the moment I wanted to enter a retino within a figure in autocad I get a written: error while reading the pattern file, then do ok and as if nothing happened, I normally insert my retino. I ask you, why does this warning window come out? I didn't happen before. What would you mean? I attach the image.
a probable cause could be the path of the reference file of the retino used. but finding a solution awaits more quoted interventions!
Maybe you went to open a format before your autocad version and at the time of entry of the autocad dash gives you error. another hypothesis, it may be that you have uploaded to the autocad of the nets downloaded from the internet and here may exist problems of path of the reference file.
I don't think it's a reference file path problem, romi says in fact:
....in the moment I wanted to enter a retino inside a figure in autocad I get a written: error when reading the template file, I then do ok and as if nothing happened, I normally insert my retino...
Does it do it with any file always?
