error!!!!! !
  • Thread starter Thread starter cecespas
cecespas
I don't know where to put my hands and since this morning I try to open the asses of a proggetto but aimè miscarriage.
this and what comes to me video
solid edge v20
internal error: invalid status 0x248
This part contains internal inconsistencies. contact gtac support
You used my hair per square
solid edge v20
Do a search in archive. It is a problem that is generated when you open files created or saved with pirate license. There is no solution if you don't remake the files or send them to the siemens that will put them to you, at the price of 100 euros each and the communication of who generated the files.
If you had used the search function on the forum you would have answered yourself.
the file was created with non-original license. for two years we talk about it and every time it is always the same story.
Read the forum rules first!
Thank you
...clear, right? ?
Thank you
in the meantime I apologize but in the hurry I have not read the forum and cmq thanks a thousand of the celery answer that you have given me I humbly ask you all
I'm sorry, I'm still asking, but I can't fix this? I think it's just the program that since the client gave it to me with 18 and 20.
Is that you uploaded files made with v18 on the v20 provided by your client and this happens?
or are they files from other sources? Typically error should occur when you charge on a regular license a file generated with pirate license.
Try to see what's written on the screen I'm training you, if there's fanciful stuff like "pirates crew form jamaica" then maybe... .
but you can't have uploaded a file from 20 to 18. It would be the first time it happened! !
The old man doesn't see the new one.
if you open with 18 a file of 20 tells you that it does not open it (impossible to open the file).
in your case you open the file and warn you of that error.
solution?
convert in step and import everything with your licensed version losing all the info and features or ask for support but I'm sorry (it seems to me that for each file to be recovered they asked $300).
alternatively tell your client that you buy licenses and that you do everything.
It may be that there is only one file that generates the warning (maybe it's not your client's fault, but he in turn took a file from who knows).
solution?
I have the 18 licensed regularly bought my client asked me to develop a proggetto they had started with the 20 that now I know it is not valid and I couldn't do it if not to remake the whole daccapo that at the point was better and seen the urgency they told me you we give you a 20 good (good hollow stigmas) however now I called it and told him some nice.
thanks again to all
